bikendan
Oct 14, 2014Explorer
joedekock wrote:
My only complaint is that the trailer accumulated a lot of moisture by the morning. All the windows were covered and when we packed up, under the mattress was a little wet from moisture too. I think next time I will get a small dehumidifier to help with this.
sounds like you sealed up your trailer like a submarine!
you have to allow for air movement. keep a roof vent open and open a bit of the tent window.
some hybrid owners put their bunk fans on low.
if you seal up any RV, let alone hybrids, you'll get condensation if the air isn't allowed to flow, especially where you sleep.
and since the sleeping area of a hybrid, is a low ceiling tent, that moist air that you're breathing out will collect on the tent's ceiling.
air movement is the cure, along with PUGs.
now moisture under the mattress is different, in a way. i've had success with an old wool blanket underneath.
hybrid mattresses have either a fabric bottom or vinyl bottom. the fabric ones sometimes collect moisture overnite, the vinyl ones apparently don't.
again, allowing for some air underneath will solve this. same thing happens on boats, due to being on water. there are a number of expensive products for boats that deal with mattress condensation.
some hybrid owners have gone to a thicker mattress or foam topper to get the body heat farther away from the cooler bed platform.
