Cummins12V98 wrote:
IdaD said: "The 68RFE is my trucks weak point"
Have you had issues? Honestly there are not many issues with that trans unless you add a tuner.
Accumulator plate failure which my diesel shop said is quite common and the internet agrees. I could still drive it but not higher than 3rd gear so I was able to limp back home and then to the shop. Ruined the valve body too. $2500 to fix with upgraded parts so not all that expensive, but any problem that renders the truck unusable is a big deal in my book. Truck is completely stock.
