dodge_guy
Oct 10, 2016Explorer II
No they are a decent rear axle! The 9.25 is one of the best out there. I've never seen a gear set go bad, only pinion bearings and very very rarely carrier bearings. $2500 sounds a bit much. Are they putting a used axle in it? If so axles can be found for less than $500 and labor should be around $500! I think someone is inflating thier prices because you are in a bind!
And FYI....GM and Ford have similar rear axle bearing failures.
As far as the recalls go! Call Chrysler and see if your truck is one of the ones included in the recall!
