propchef
Mar 23, 2022Explorer
JRscooby wrote:
IMHO, if a blowout on trailer causes you to loose control or roll your rig you didn't have control before the blowout. (Fact is the rear axle of TV is where a blowout is most likely to cause loss of control) Just trumping here, but I think there is a better chance with single axle that the driver would notice a issue with all the tires on one side, pull over and stop before the tire beats the snot out of trailer.
Single axle takes less power to turn, because don't need to force axles out of line or slip tires sideways. If fenders are inside body, tandem will use more space.
I would think the use of a TPMS would eliminate this worry.
