Gdetrailer
Mar 23, 2022Explorer III
propchef wrote:JRscooby wrote:
IMHO, if a blowout on trailer causes you to loose control or roll your rig you didn't have control before the blowout. (Fact is the rear axle of TV is where a blowout is most likely to cause loss of control) Just trumping here, but I think there is a better chance with single axle that the driver would notice a issue with all the tires on one side, pull over and stop before the tire beats the snot out of trailer.
Single axle takes less power to turn, because don't need to force axles out of line or slip tires sideways. If fenders are inside body, tandem will use more space.
I would think the use of a TPMS would eliminate this worry.
"Blowouts" are a sudden loss of pressure event which will depressurize the tire so fast the TPMS will never register it fast enough to make any difference what so ever.
A single axle trailer, you will notice a change in handling pretty quick since there is no other tire on the side to hide the flat.
People live and die that "Technology" will save them, this is a case of TPMS will alarm well after the fact and during the time you are fighting the trailer to a safe stop so you will be well aware of the flat.
TPMS might make some difference on dual axle trailers, since you have two tires on each side you may not notice much change in handling..
But in reality no one should ever rely on TPMS to tell the hole story, it is not a substitute for physical inspections, should always check your tire pressures daily and verify that the tires do not have any physical changes or damages whenever you get out of the vehicle for rest stops..
I always do a quick walk around my trailer and vehicle to verify both do not have any noticeable physical damage to the tires. I make sure they appear to have "normal" aired up look meaning that they look like they have plenty of air pressure every time we fuel up, or stop for rests or food.
