jerem0621
Sep 12, 2014Explorer II
What probably happened is the front axle was on the front scale pad and the back axle was MOSTLY sitting on the front scale pad with some weight on the second pad.
Its entirely possible that the GCW is correct. If so, then your pin weight is anywhere from 1900-2300 ish lbs.
If my theory is correct then your truck when hitched up is sitting at 8480 lbs.
A re-weigh is in order, making sure that the front axle is on pad 1, the rear axle is on pad 2, and the trailer axles are on pad 3.
Thanks!
Jeremiah
Thanks!
Jeremiah
44,056 PostsLatest Activity: May 04, 2014
