Old-Biscuit
Nov 01, 2013Explorer III
ronny7800 wrote:
Be prepared though... the Dexters on mine have an arm you need to lift up when you loosen the shoes back (ideally you want a bit of drag). Had to insert the brake spoon in one hole, and lift that arm with a flat screwdriver in the other hole.
Then you have self-adjusting brakes.......that lever is attached to pivot point of shoes and engages the star wheel when brakes are used.
They are forward self-adjusting (and should adjust in reverse also)
44,070 PostsLatest Activity: Jul 21, 2026
