fireman41
Oct 18, 2014Explorer
buddyIam wrote:
Firemen
You will not lose a wheel due to broken axle on a full floater.
You will with a semi floater except in the case of a tapered bearing semi floater.
A stick of dynamite will blow a wheel off both the semi floater and full floater axles. Lol
My gosh your right. What was I thinking.
Did you read the part about the wheel bearing failure causing it to chew the heck out of the hub and spindle that my cause you lot lose you wheel and hub assembly with the axle shaft attached.
it does happen.
44,056 PostsLatest Activity: May 04, 2014
