buddyIam
Oct 19, 2014Explorer
The closer you run to max payload. The sooner you should expect to provide maintenance. And the sooner you could expect to encounter failure.
If you run at 100% payload does not mean you are unsafe. It means that you should expect failure sooner than someone running at 50% payload.
If you're over payload the above doesn't apply. Over payload and the manufacturers declare that you are unsafe.
If you want to take their advice then you should always run no more than 100% payload. This also means you are on the edge of maintenance schedules and should always use premium oils etc.
At least that is my interpretation.
44,056 PostsLatest Activity: May 04, 2014
