Majja13
Oct 20, 2014Explorer
This thread has been so very entertaining to read. I think I may start a new one that says OMG can you believe what the new 1 tons are rated at, because it is all the same.
IMHO I feel that the build quality and the materials are much better then they use to be. So from what some have stated in this is that if I drive a 1/2 ton and I do I should stay well away from my Max limits. However if I make the jump to a 3/4 or 1 ton It is ok. As a HD truck was meant to tow at the very max of its stated limits where as a 1/2 is not.
Any mechanical device can fail even when used as designed, I mean it seems a little unreal that a new F150 could pull 10k with close to a 2K payload, but then look at a F350 HD that is up around 4k payload and 17k towing all the numbers have gotten significantly larger. For the better or worse that is for you to decide.
44,056 PostsLatest Activity: May 04, 2014
