monkey44
Oct 20, 2014Nomad II
QUOTE: "How far below? Monkey44 suggest that I stay around 1/2 the truck's payload."
NO! Monkey NEVER said that -- if you all would read the posts it would help.
Monkey said "A truck with half it's payload is safer than a truck maxed out at it's full payload." That's different than Monkey saying we should drive with half our payload.
I also never said "Drive at half the speed limit" as some one else claims.
You guys really need to read what is written, then take a minute to actually understand it, before you all jump on my case, or any other post. Half the time, these 'folks that argue" whip out PART of a statement, wiggle it around so it says something else, then use it to disagree with a post or support their own posts ...
the only thing Monkey ever stated was: If you drive a 1500/150 at it's maximum capacity, or drive a 2500/250 at half its capacity, the 2500/150 will be safer.
PERIOD>
I never said drive at half your payload -- but I'll add to that now, to clarify my meaning ... if you are carrying a maximum payload on a 1500/150, and switch that payload to a 2500/250, you will only be carrying half it's designed carry capacity (more or less) and therefore, you will be driving under safer conditions.
Anytime you run a truck at its maximum payload, you will stress that truck to a greater degree under emergency conditions ... because sliding, swishing, braking under emergency conditions will have a greater margin in a heavier duty truck with less payload - no matter what brand or model you drive ...
So, what that means: You can drive a 1500/150 under maximum load, and probably drive safely if you choose that option. BUT if you take that same load, and put it on a 2500/250, you will be safer under any conditions, including emergencies. I choose the second option ...
That's all Monkey said, and Monkey is correct ... and Monkey only means the truck is SAFER under those HD conditions ... when we take "driver ability and skills, and even attitude" and lock it into the equation, that changes everything.
PERIOD>
44,056 PostsLatest Activity: May 04, 2014
