jbnery6465's avatar
jbnery6465
Armada to Pull 33' Lightweight TT
2008 Armada LE AWD w/Tow Package.
I've done a lot of reading on this forum related to this topic as we're looking to become first time TT owners. Woohoo! Our intention is to have few trips a year with long extended stays. Some trips will make yearly to Oregon and to Arizona, from San Diego. It could also serve as a temporary home until our house is built on some land we own - thus why I'm looking at the longer range.
The topics that I've read related to how long of a TT an Armada can safely pull are more than 4-5 years old, and the focus quickly shifted away from length and focused on weights. But there are new trailers today that are in the 31'-33' that have a dry weight of 5800lbs - 6400lbs, and hitch weight in the mid-700's. I did a whole spreadsheet not only with "estimated" dry weights, but also what I think our loaded weight would be (2 adults, 4 kids, gear, empty tanks). So hypothetically assuming if all my weights are within range, loaded properly, have the right WD hitch, drive in Tow Mode in 4th, etc, can I safely pull these trailers? They are dual axle, not sure if that makes a difference.
Thanks for hearing me out, I'm looking forward to learning from you all. Thanks in advance for the input!!
  • Thank you all for the feedback. I didn't really think about the age of the Armada, good call. I do have a newer used engine in it that's at 90k, but all the suspension and brake components are new. But a safe and fun experience is what I'm after.
    I've seen many on rv.net and clubarmada.com who max out at 30' in length with no issues going cross-country. So I'll keep searching around for shorter trailers and see what I find.
  • One of the items I find interesting when a mfg states a towing capacity, is they never mention whether their rating is good for a trip to a camp ground 100 miles away on flat ground, or going across the US crossing the Continental Divide on very long trips over several months.
    The Armada will probably do fine to a campground a 100 miles away, but it doesn't have the transmission, rearend or brakes for longhaul traveling.
    Bill
  • I would not push the weight limits of the Armada. That is a FIFTEEN year old vehicle that is now going to start towing a heavy load. Yes, it was built to pull and Tow a set weight limit but things are worn in from your driving in the previous years. Now you're going to put it under different strains and stresses.
  • Maybe in theory. I wouldn't personally do it and I'm far from the weight police. Even if the weights check out that's a big sail behind a marginal tow vehicle with a relatively short wheelbase. Plus with 6 people you'll have quite a bit in the vehicle too. If your kids are anything like mine, anyway. That's just my gut reaction without knowing any real specifics.
  • What you need to know is the “actual” weight of the front and rear axles of the Armada when is loaded and ready to go (minus trailer), but including dog, kids, snacks and everything else in the Armada. Once you know that, and the GVWR of the Armada, you can figure out what is left over for tongue weight of trailer.
    For more information Clicky
