Irdew wrote:
Here you go a Ram 3500 DRW long bed with a 2015 865 loaded up and ready to go. GVW is 14000 lbs on that truck.on the scale with driver and passenger.
Steer axle 5940
Drive axle 8320
Total. 14260
Thanks for the numbers.
A moderately equipped 2013-2018 Ram 3500 DRW CC LB 4x4 Cummins scales totally empty (with a full tank of fuel and driver) at around 8,400 lbs. Based on your total scaled weight of 14,260 lbs., and assuming you have a similar truck as I've described, it's possible you may have ~5,760 lbs. of payload. No doubt a good portion of this payload is your AF 865, but exactly how much is anybody's guess.
