thomas201
Aug 20, 2021Explorer
I have dug into it a little. For gasoline, if you want a deck tank and want to use it as an aux tank, then ATI is maybe the only one. You have to use a pump, return line, and probably close up the system to prevent a check engine light. (Does Titan make one yet? They are pricey.) I plan to wire it in with a timer, and pump gas from 1/2 to 3/4 of the truck tank in my travels.
I have found that people make mistakes, so just like my work days, I run the math again. Even more so when it concerns my own health, safety and property. When you consider that the flash point of gas is about -40 degF and a pick up has plenty of ignition sources, then yea, I am going to look at the system, before installation. The cap on the aux tank still needs its own pressure/vacuum reliefs, I don't want to suck it in or pop it from a line kink.
Three thoughts:
Don't make anything you can't unmake.
What have I forgotten?
How can I make it better?
Three thoughts:
