thomas201
Aug 20, 2021Explorer
One other tidbit to consider. It might not be necessary to close off the rollover vent on the deck tank, and make a closed system. Taking the weight of gasoline to be 6.3 pounds per gallon, you only need about 3 feet of head to equal 1 psi. Now, for the EVAP system the test pressure is 1 psi, so the operating pressure is lower. This explains why in the installation instructions, it is suggested that you may have to close up the system, not you must plug or plumb a return from the rollover valve. You still need a return line from the gas tank to the deck tank. ATI sells a fill line insert, that has two taps, one for fill the other for return. This would make a simple and safe system that does not set a check engine light. You are close on pressures, but I will try the safest/easy way first.
