Huntindog
Feb 11, 2015Explorer
Mark and Linda wrote:Loctite is your friend.
I am in the process of doing a security check on mine. If I find any loose I will put bolts with self locking washers and nuts. If anyone does this to theirs...to get the washers and nuts on the hard to get to ones....put a piece of wire up through the hole...drop washer on and the nut...place finger on end and follow it back down to the hole. Remove the wire and insert the bolt.....keeping finger on the washer and nut.
I use it on every nut or bolt I find loose. The ones I use it on never loosen up again.
