joeshmoe
Aug 30, 2014Explorer III
HMS Beagle wrote:
What you have is a steel bracket thru bolted in the middle of a plywood panel, fastened with small screws or staples at its edges. There is a small (plywood) corner block at the forward edge providing some reinforcing. This is so inadequate as to be laughable. A continuous plywood panel would pull out at only very slightly more force.
Even my wife, who knows nothing about this stuff, saw that and said, "That's it??" "That's all that's holding that piece in?" Yep.
As far as solid, continuous panel being used instead, I agree. Would have likely pulled loose too, but possibly kept it on the truck, thus only requiring repair rather replacement of the entire camper and truck bed.
Regarding turnbuckles, my Northwood 'Arctic Fox' manual "recommends" a spring loaded type. That's it. Aren't the happijacks that were used in both situations, spring- loaded? It has way more to say about washing and cleaning the camper than anything about the turnbuckles. I guess they leave that part up to the tiedown and turnbuckle manufacturer. Which begs the question, if NW in fact recommends only Torklift, why isn't there literature or something in writing presented to the customer before the camper even gets put on the truck and leaves the dealer?
In both cases, they were using spring-loaded type turnbuckles as recommended in the manual. How, then, can they put the blame on the turnbuckles that THEIR manual recommends?
Not that it means anything, here's the warranty text from NW:
warranty link
ONE YEAR LIMITED WARRANTY
FOR TRUCK CAMPERS MANUFACTURED BY NORTHWOOD MANUFACTURING
SOLD IN THE UNITED STATES AND CANADA
COVERAGE PROVIDED
Your new truck camper, including the structure, plumbing, heating, and electrical systems, and all appliances and equipment installed by the
manufacturer, is warranted under normal use to be free from manufacturing defects in material and workmanship.
This limited warranty extends to the first retail purchaser and his transferee(s) and begins on the date of original retail delivery or the date the
camper is first placed into service as a rental, commercial or demonstrator camper (whichever occurs first). This limited warranty extends for a
period of one year from such date. Written notice of defects must be given to the selling dealer or the manufacturer not later than ten (10) days
after the expiration of the applicable limited warranty. Warranty repairs, if required, will be made without charge after your camper is taken to the
dealer or manufacturing plant location.
OWNER'S OBLIGATIONS
The owner is responsible for normal maintenance as described in the Owner's Manual; however, minor adjustments (such as adjustments to the
interior or exterior doors, LP regulator pressure, cabinet latches, TV antenna control, etc.) will be performed by the dealer during the first 90 days
of warranty coverage. Thereafter, such adjustments are the responsibility of the owner as normal maintenance unless required as a direct result
of repair or replacement of a defective part under this limited warranty.
DEALER'S OBLIGATIONS
By agreement with the manufacturer, the dealer is obligated to maintain the camper prior to retail sale, to perform a detailed predelivery
inspection and to repair or replace any parts necessary to correct defects in material or workmanship.
WHEN A DEALER DOES NOT RESOLVE A PROBLEM
If the dealer is unable or unwilling to resolve a problem which the owner is convinced is covered by this limited warranty, he should contact
NORTHWOOD MANUFACTURING at the address listed below and provide the manufacturer with a description in writing of the problem and
attempts made to resolve it.
MANUFACTURER'S OBLIGATIONS
Upon receipt of notice of a claim which the dealer was unable or unwilling to resolve, NORTHWOOD MANUFACTURING will repair or replace
any parts necessary to correct defects in material or workmanship, or will take other appropriate action as may be required.
WHAT IS NOT COVERED BY THIS LIMITED WARRANTY
THIS LIMITED WARRANTY DOES NOT COVER THE FOLLOWING:
1. The batteries which are covered by the separate warranty of the manufacturer.
2. Damage caused by or related to:
A. Accidents, misuse or negligence
B. Failure to comply with instructions contained in the Owner's Manual
C. Alteration or modification of the camper.
D. Environmental conditions (salt, hail, chemicals in the atmosphere, etc.)
3. Normal deterioration due to wear or exposure, i.e., fading of fabrics, drapes, carpet wear, etc.
4. Normal maintenance and service items such as light bulbs, fuses, lubricants, etc.
5. Extra expenses such as transportation to and from dealer or manufacturing plant location, loss of time, loss of pay, loss of use of the
camper, inconvenience, commercial loss, towing charges, bus fares, vehicle rental, incidental charges such as telephone calls or
lodging bills, or other incidental or consequential damages.
This limited warranty gives you specific legal rights, and you may also have other rights which may vary from state to state.
Dealers or any other persons are not authorized to make modifications to this limited warranty, any additional statements concerning this limited
warranty, whether oral or written are not the responsibility of the manufacturer.
BRAND NAME MODEL SERIAL NO.
