OttawaCatLite's avatar
Dec 03, 2016
Atwood 8525 IV Furnace - No Blower Run
Hi All,
I have been doing battle with my 2002 Coachmen Catalina Lite, with an Atwood 8525 IV furnace. About a year ago, after over a decade of perfect operation, it suddenly would not start up any longer. By that, I mean the blower motor will not start.
I'm sota at my wits end, as I'm electrical engineer and this isn't the hardest thing in the world to solve. So I'm reaching out here for some help and advice.
First, what I have done:
- Confirmed good 12v from inside fuse to outside power switch for controller board
- Confirmed my power power switch is good and 10A breaker at the blower is good.
- Confirmed the blower motor is good by jumping 12v to it directly.
- REPLACED THE IGNITOR CONTROL BOARD /w BUILT IN RELAY (31501) ENTIRELY. Same result. (note this is a 2002 model and doesn't use the separate relay module anymore)
- Tested continuity for thermostat and even bought a replacement just in case the anticipator level was bad. Same result.
- Downloaded, scoured, read every technical document I can find on these units and followed the schematics to this point.
What I am stuck on and maybe where I can ask for help:
- I have 11.5v ~ 12.0v on blue wire for TH to ignitor board when it's not plugged into the board. As soon as I plug it into the board, it drops to around 2.0v taken at the circuit board. Is this normal? Doesn't seem like it to me.
- I have around 6v coming to the thermostat to close the circuit when not connected. Is this right? When connected to the thermostat, it drops to around 2.0v (I see consistency with my 2.0v reading noted above).
- Could I possibly somehow bypass the thermostat connection level to take the wire out of the equation?
- Could I possibly have gotten a bad replacement ignitor control board. It should be noted that my old board was mode with edge connector (shown) and the new replacement came with an edge connector standoff for backwards compatibility.
- Is there a test sequence to lab proof out the ignitor board? I can't find anything more than the tech spec doc they send with the replacement giving me the pinouts. So I don't know the trigger steps to introduce and test out the board.
Any help is HUGELY APPRECIATED!
Old Board
New Board Advertised Replacement
New Board with edge adaptor
