PaulJ2
Dec 03, 2016Explorer
The blue power feed wire either has a poor, high resistance connection somewhere or your battery is dead. 11.5 to 12 volts is a discharged battery. If the circuit board load was enough to pull the voltage down to 2 volts it would have blown the 10 amp fuse. Are other things like lights in the camper working fine, bright, etc?Where did you get the voltage from to jump the motor directly?
Just trying to eliminate some things here. I think board is ok.
44,070 PostsLatest Activity: Jul 11, 2026
