OttawaCatLite
Dec 04, 2016Explorer
budwich wrote:
don't have any answers for you but more questions? what wiring have you got connected at the thermostat... for that matter, what thermostat are you using?
The 6v going to the control board (TH) doesn't seem right... I would expect "supply voltages" which would typically be 12v.... or possibly ground depending on operation wiring (ie. "switched" ground or voltage).
Since you indicate that direct wiring of the motor works... follow that wiring back to the control board... monitor those same connections when operating the thermostat... what happens? Of course, check your grounds (using resistance not voltage on your meter... to a known ground point).
Thanks for the reply. I'm using the original and original replacement 38453 model, noted here: http://www.rveparts.com/rv-furnace-hydro-flame-wall-thermostat-white-38453-rv-camper-parts/
Good points. Perhaps I'll try to bypass the wire in case I have a short out or corrosion somewhere that's degrading the voltage. The 6v really raised my eyebrows.
I'll keep at it!
