yankee_camperExplorerApr 20, 2014Atwood Hot Water Drain PlugI know it's been discussed before but if the drain plug on an Atwood HWH is plastic so as not to create a metallurgic reaction to the aluminum tank then why doesn't the pressure relief valve or the th...Show More
beemerphile1ExplorerApr 20, 2014Drain plug is nylon, the others are probably brass. Neither will corrode but nylon is much less expensive than brass.
Related ContentAtwood water heater problemAtwood water heater drain plug tighteningHouse battery drainGrey water tank won't drain completelyAtwood water heater problem
