yankee_camperExplorerApr 20, 2014Atwood Hot Water Drain PlugI know it's been discussed before but if the drain plug on an Atwood HWH is plastic so as not to create a metallurgic reaction to the aluminum tank then why doesn't the pressure relief valve or the th...Show More
KalaitExplorerApr 20, 2014By water heather plug is nylon as well, will be watching for leaks. Thus, far I have seen none
Related ContentAtwood water heater problemAtwood water heater drain plug tighteningHouse battery drainGrey water tank won't drain completelyAtwood water heater problem
