mobeewan
Apr 27, 2014Explorer
Suburban water heaters have an over pressure and temperatures relief valve and a steel tank and steel plug with anode rod.
Atwood water heaters have an over pressure and temperatures relief valve an aluminum tank and a plastic plug. If it was true about the plug being designed to blow out if over pressurized, why would the relief valve be needed. Someone needs to recertify the RV course. Plastic plug vs aluminum tank threads equals no damage to threads. I actually replaced my pastic plug with a brass nipple, ball valve and hose barb on an older trailer I have.
44,057 PostsLatest Activity: Mar 12, 2026
