kirkl wrote:
So you actually have to kind of rewire them for them to work with the gama wireless?
Yes the way they are wired now you have a box fused with a 2wire -12v pos and neg running to each jack that's switched ,from that jack that has the switch wires run to the pas side jacks
So the drivers side has the needed wiring
You have to either run pos and neg wiring to each pas side jack or from the existing wiring at the drivers side jack to the gamma controller , in other words each jack has to be individually wired to the gamma ,
