independent_TJ
May 10, 2017Explorer
When I cut off the leaking twist-on hotwater-inlet connect, I replaced it with a new connect that looks like this. I don't see any form of a shut-off valve built into it...right? But how does water get to the hot faucets if the hot water tank is not filled to the outlet pipe connection..?? So confused..
Connector
Connector
