budwich
May 10, 2017Explorer
I can't tell from your "textual description of activities tried", are you releasing the pressure in the hot water tank using the pressure release valve at the side of the tank (where / near the burner / flame area)? IF you open that valve with city water connected, water should shoot out. Further doing the same "test" by opening the tank drain plug should see water coming out. IF not, you have a by pass valve somewhere in side set wrong.
