independent_TJ
May 10, 2017Explorer
Budwich, I was referring to the pressure valve of some sort that is built into the city-water twist-on connection. It has a spring, I think, that keeps water in the TT's lines from draining OUT of the city-water connection when city-water hose is not connected. When I press this, it shoots water OUT....so I know city-water is building some pressure in the TT lines when the faucets are closed, but not filling the tank.
Coincidentally, I have also tried the outside pressure releif valve that you refer to, and again water does shoot out of the outer relief faucet....
But the tank feels and sounds empty... I never hear it filling (when i gently lift/rock the tank or tap on it) except for an occasional splash.
Maybe I am crazy, but it feels/sounds empty....??
