independent_TJ
May 10, 2017Explorer
I am fairly certain it filled some the other day because I turned off water quickly when I saw connection leaking , disconnected the heater-inlet (bottom) and about 1/2 - 1 gallon of water came out. (There is no floor or insulation until I finish the plumbing and appliances, so the water went straight to the ground..
