Old-Biscuit
Apr 08, 2017Explorer III
Flame Proving signal is generated by MAIN FLAME.......ionization creates AC Milivolts.
Signal goes back to circuit board to PROVE flame is lit.
W/O signal circuit board shuts gas valve.
Spark Electrode Assembly mounting screw proves one source of grounding for electrode----clean/tight connection
Spark Electrode High Tension wire connection at transformer needs to be clean/tight
Spark Electrode Ceramic insulator....if cracked signal will track to ground vs getting back to circuit board (fire off WH at night in dark and watch for tracking)
Spark Electrode needs to be 'engulfed' in Main Flame so signal can return...any sooting/carbon on electrode tip will stop milivolt signal
Spark Electrode Gap needs to be 1/8" for a good strong spark
Ground wire from connectr to WH frame..clean/tight
Circuit Board mounting screw.....provides grounding
Doesn't take much to stop that AC Milivolt Signal
44,057 PostsLatest Activity: Mar 12, 2026
