Old-Biscuit
Apr 09, 2017Explorer III
dave17352 wrote:
This is a very occasional problem and once it is running there seems to be now issue. Where I came up with the moisture idea was it seemed to happen when filling the water heater with relief valve open thus spilling some water and there you go it wouldn't work. By repeating the process close to a dozen times I am sure that the moisture was causing my issue and I bet a few others at times.
No need to open T&P to fill water heater.....just open faucet hotside to expel air and allow WH to fill.
I can spray down my WH circuit board, spark electrode high tension wire, spark electrode assembly and it does NOT affect WH operation/flame retention
YOU have a grounding issue or a tracking to ground issue
44,057 PostsLatest Activity: Mar 12, 2026
