dave17352
Apr 10, 2017Explorer II
mkirsch wrote:dave17352 wrote:
This is a very occasional problem and once it is running there seems to be now issue.
It will work, until the moisture-sensitive component, or ground connection, gets bad enough that it won't anymore. Wouldn't you rather fix it once and for all instead of having to cart around yet more tools, and fire up the generator just to make the water heater work?
Not really. Like I said this is twenty years old and may be close to the end of its life. I also am very confident of what the problem was and that I can keep this problem from reoccurring. If I am wrong I will replace the board and probe. If I am right I will spend nothing. :)
44,057 PostsLatest Activity: Mar 12, 2026
