theoldwizard1
May 30, 2017Explorer II
Old-Biscuit wrote:
Not needed...
Just clean tank wall and make sure t-stat is held tight against wall.
My daughter brand new TT had a problem with the water heater not re-lighting. After 2 (or was it 3 ?) attempts by the dealer (including a charge for re-adjusting the flame sensor), simply cleaning the t-stats and the spot where they contacted the tank, solved the problem.
OP - Curious, how did you realize the tank was over heating ? There is a PT valve just like on your home water heater tank, so you were not really in any danger. There is also a thermal fuse that will melt cutting off all power if thing got REALLY hot !
