Old-Biscuit
May 30, 2018Explorer III
SAR Tracker wrote:
Batteries charged? You'll need 12v to make the igniter work.
X2
Also hard to visually check fuses.
Remove the thermal cut out fuse and just wire directly to t-stat
(Brown wire to t-stat then from t-stat to circuit board)
Try lighting Water Heater.
OR
Use a voltmeter to test for DC Voltage
12V DC to On/Off Switch
12V DC from switch (BROWN) to 'thermal switch' to T-stat' to circuit board
12V DC from circuit board (RED) to ECO to gas valve solenoid
Solenoid (Black) to ground
44,055 PostsLatest Activity: Dec 23, 2025
