RAMBOYExplorerMay 30, 2018Atwood Water Heater Will Not LightThe Atwood water heater in my 1 year old TT does not light. It worked fine last year. There is no clicking noise when I turn on the water heater power. It is a propane-only heater. There is propan...Show More
dkellerExplorerMay 31, 2018Are you getting propane to the heater if you are it could be the controller as I had same issue was covered under warranty.
Related ContentAtwood water heater problemWater Heater Replacement RecommendationsWater Heater Leak on start up.Suburban SW12DEL Water Heater On/OFF switch melts???Atwood hot water heater
