Jfet
Jan 12, 2015Explorer
Are the t-stats in series with the gas solenoid valve on the water heater burner? If they instead go to a controller board, perhaps the problem is on the board and not with the t-stats.
Should be easy enough to check the t-stats with a multimeter to see if they are opening when at temp.
44,057 PostsLatest Activity: Mar 12, 2026
