AnEv942
Jan 13, 2015Nomad
Just guessing model?
On the wiring
service manual
Have to ask, thermostat ECO replaced twice- either instance did replacement work?
Positive contact to tank would also be my first verification. If you unplug wire(s) to valve from tstat/eco after it reaches temp(& should shut off) does it?. As you are able to manually turn off, I'm 'guessing' though its not the valve/solenoids sticking once powered on.
As mentioned power has to go thru even if there is another issue. Remove the thermal buttons and test outside. Simple hair dryer would bring to temp pretty quick. Meter to see if continuity breaks (or jury rig as inline switch on low voltage light or something).
On the wiring
service manual
44,057 PostsLatest Activity: Mar 12, 2026
