Old-Biscuit
Feb 10, 2017Explorer III
13V on Orange wire from 'Gas' On/Off Switch to circuit board
So with gas switch ON
Check for DC Voltage on Brown wire (very bottom one---BRN 1 ) to thermal fuse ...to t-stat...and back to circuit board on brown wire (top one--BRN 3 )
This circuit MUST make up before DC Voltage can go to spark/gas valve
Thermal Fuse blows at 190*F...one time fuse
T-stat has to have DC Voltage to & thru it ---- water temp has to be below 110*F for it to CLOSE
Connectors need good contact on board
Then should have DC voltage on red wire (RED 4 ) to ECO then to Gas Valve solenoid
Check all grounds
Works on Electric ---same circuits(thermal fuse/t-stat/ECO etc
SO could be bad 'gas circuit' on board
Check all grounds
44,066 PostsLatest Activity: Oct 04, 2013
