Old-Biscuit
Feb 12, 2017Explorer III
bjarnold wrote:
For whatever reason he said he had the inverter installed and never used the gas function. I filled the LP tanks and fridge works fine on gas so I am going to leave it that way. The only reason I question the inverter is that is the only thing I unhooked after buying the trailer and wasn't sure afterwards if that could cause the water heater issue. I measured 12 volts with a voltmeter at the orange wire going into the control board. The brown wires have no power
bjarnold wrote:
FIXED- I checked the part number on the circuit board on my Bounder and it matched the trailer. I swapped the board on the trailer and it fired right up
As I posted earlier.
Check BROWN wires....no power then bad board
Nice to have another board to swap with.
IF you plan on replacement.......Dinosaur Electronics Board----MUCH better quality/pricing
44,066 PostsLatest Activity: May 16, 2026
