hohenwald48 wrote:
Funny how everyone worries about "flushing the crud" out of the RV HWH. When was the last time you flushed your HWH at home? I bet for most folks the answer is never.
I agree 100 percent but being that the RV HWH is only 6 gallons and is used in various areas with hard water or high calcium it's probably a good idea to flush them.
The Suburban used an anode rod and the rod is designed to break down the minerals in the water and it does leave behind sediment.
Maybe some with more Atwood experience then me can weigh in on sediment in an Atwood.
I know my other TT with the Suburban had a lot of sediment each year.
On a side note I think most home HWH's have inlet tubes that create a swirl within the tank to prevent sediment.
