rvten
Nov 11, 2014Explorer
gkainz wrote:
transmission experts I know say "DO NOT FLUSH!" ... drain the pan, change the filter. If you want the TC fluid changed, remove the output line to the trans cooler and idle the engine. As the old fluid pumps out, add the same amount into the fill port. Once you have clean fluid pumping out, stop, shut down, reconnect, restart, check and set proper fluid levels.
Just had our Toad done that way.
