ShinerBock
Jun 09, 2018Explorer
Grit dog wrote:
Suncoast, goerend or Firepunk if you're interested in a bulletproof or upgraded trans.
If your making stock or near stock power though, save your money and find a decent shop to diagnose, service, adjust bands, or possibly rebuild, provided your ok with the OE mushbox performance of a 47/48re.
If I was rebuilding one today for stock power I'd still get a good aftermarket tq converter and an upgraded valve body just to improve the transmissions behaviour.
You don't NEED upgraded anything for what a stock 24v puts out and at only 150k on a 18 year old truck, how many more miles vs $ sunk into a trans do you expect out of it?
X2
No need to go with a Suncoast or any of the others transmissions built to handle more power unless the engine is putting out more power than stock. A good TC that has a lower than stock stall speed along with a good valve body(such as Revmax) that allows for more line pressure with trans tune will go a long way in transmission behavior and longevity on stock or even slightly over stock power levels.
44,072 PostsLatest Activity: Aug 23, 2026
