Miles_Away
Jan 04, 2014Explorer
trucker495 wrote:
Miiles away do you happen to have a part/moden number for the pump? Oreilleys here in Tucson can't seem to help me
Kyle
I went on the O'Rielly web page and found one just like mine except it is only 6 volt, but I'm sure they have one just like it in 12 volt. It is an Airtex # E8011. They also have a Mr. Gasket #12S. Both are low pressure (5 to 8 lbs). They run about $50. (sorry about the under estimate on price). The filter I use is a WIX #32123 and it screws onto a base that you must mount next to the pump. That part number is WIX 24309. The reason I use a pump is that gravity feed will not flow through the filter. If you choose not to filter your AUX tank, then you will not need a pump. Good Luck!
44,068 PostsLatest Activity: Jun 10, 2026
