Grit_dog
Feb 16, 2016Trailblazer
Never seen one, but if you had an aftermarket lift pump, you could plumb a valve, tee, line and install an aux switch to use the lift pump as a fuel pump. Add an aftermarket tank with bigger capacity.
That's about the only way I can think of to do it. I've never see a second aux tank frame mounted, but you may be able to retrofit a tank from a cab n chassis truck in place of the spare tire. Again you'd be limited to a low volume lift pump type pump afaik.
Seems like a lot of trouble and $. A small diesel generator to power a TC will literally sip diesel. 5 gal will go a long way.
And there's about a zillion in-bed transfer tank setups, but I haven't ever seen one that would fit with a camper......
44,066 PostsLatest Activity: May 13, 2026
