Bob Vaughn wrote:
I had an auxiliary diesel fuel tank installed today. It has a manual shut off valve. I would like to have an electric solenoid valve put in the line so I could open the valve to allow the fuel to drain into the main tank when I need it. The ones I have found cannot be turned on for long enough to drain the tank because the solenoid burns out. I am looking for one that I can turn on and leave on until the tank is empty then turn it off. Any first hand experience would be appreciated.
This will do what you want and it's designed for it. Lifetime warranty
Switchable Fuel tank valve
