akcooper9
Mar 26, 2018Explorer
bamafeaver wrote:
Does anyone have a auxiliary fuel tank for a gasser. If so what kind. 2500 HD 6.0 gasser pull a fifth wheel. Thanks
https://www.rv.net/forum/index.cfm/fuseaction/thread/tid/26924844.cfm
I put an RDS in my Gas truck 5 years go. It worked perfect. As mentioned you will need to pump it to the main tank to be legal. Make sure you buy a solenoid valve to cut the flow when you turn off the pump. I also tied the rds tank vent to the evap system on the truck to keep pressure equal and no check engine light.
PM me if you have questions
