retispcsi
Jun 23, 2017Explorer
My 2014 has the dual tube filler neck started in 2013 when they went to DEF. I have a RDS 60 gal. I used it in my 2012 and now my 2014. No issues. I found out that the hose supplied with the adaptor kit on the fill tube needs to be longer so I bought some from a local NAPA store. I also used two clamps solved any leak issue. Also make sure you clamps are tight and that you have secured the brass connector to the filler kit. As far as the check engine light and gas gauge issue never had that problem.
