rhagfo
Nov 25, 2014Explorer III
donn0128 wrote:
Is this truck for towing a fifth wheel? If so the aux tank may not fit wirh a hitch installed. Why your relunctance to go with a long bed? Just curious, because with the long bed you get a 35 gallon tank. More than enough fuel for 300 to 400 miles between fill ups
X2, Unless you get a replacement tank to replace the current tank you will have very little bed space left.
Unless it is won't fit in the garage, the long bed will tow better. Then you get the bigger tank also.
