69 Avion wrote:
If you made it usable as a regular camper you could put a separate gray and black water tank as side saddles on each side of the truck with piping from the camper outlet. You could dump each camper tank into the appropriate truck tanks for extra capacity without limiting your camper usage.
Wouldn't you still have to raise the camper off the flatbed as the shower trap is below floor level ?
I suppose another hole could be cut in the flatbed for the trap and have hose connection to the grey tank as long as there was access under the truck bed .
Usability as a camper on regular pickup would be limited as there would be no tanks .
