NinerBikes
Jan 22, 2015Explorer
Please post up the link to the Youtube video for the awning replacement.
It is best to contact the manufacturer of your awning for instructions, in your case, it is Dometic.
I have the same G210 version in a 2012... w a Dometic electric, and it is not a sunchaser.
Dometic instructions required 8 turns on the rear most arm of the awning, the motor was on the front arm.
http://forums.woodalls.com/index.cfm/fuseaction/thread/tid/28106771.cfm
http://forums.woodalls.com/index.cfm/fuseaction/thread/tid/28037066.cfm
Chris Bryant wrote:
Here you go, that should give an idea. It is best to tension rolled up, with the arm zip tied against a block- just a little extended. It's 8 turns rolled up. You can tension, then put a cotter pin in to hold it.
44,027 PostsLatest Activity: Mar 05, 2025
