AaronV wrote:
Cecilt wrote:
I found some old laptop power supply's so I think I will just use those and run to my outside outlet. Since my awning is 19' what dio you do with the end with the female connector that is not being used? Also, do the lights emit any light with the awning rolled fully up. I try not to use my awning as I hate keeping it clean. So mine stays up more than it is down. Tks
I'm not sure what do with it, maybe just cut it off. These strips have cut points just about every 3". Maybe its possible to buy them in 6m lengths instead of the 5m. The lights give off quite a bit of light while the awning is closed, it started pouring down rain as I was closing it so no pictures of that.
Did you use the whole 5m under your awning or did you cut part of the strip(meaning not only the female connector but some of the LED lights?) tks
